Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3498 Questions View all
Why is my touch hard to use or unresponsive?
okay guys i have done multiple iphone 6 and plus (glass only) repairs, followed ALL the necessary steps.... whenever i get the original glass off and test everything is in perfect working condition, but whenever im done with the repair and have the new screen on everything is still working but you have to use force to get the touch to respond, like push really hard. ive tried to restore, hard reset, adjust flex cables but nothing seems to make it respond better.... WHY IS THIS HAPPENING???? and how can i fix it, its happened on the last 3 out of 5 of my repairs
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Are you using a mold? It could be that the loca mold is too far away from the actual digitizer.
Your glass could also be too thick/not OEM spec.
Comments:
I use a mold but Thats whats i was thinking, (about it being not close enough) so i put a little weight on ot as the glue dried under the light and it was still sketchy. Ill will look into the specs of my glass appreciate the help and input
by
Add a comment
Are you using OCA or LOCA, OCA glue makes it less responsive sometimes.
Comments:
Im not sure i have two different bottles ive never even looked at them i always thought it was all the same... ill look into it thought appreciate it
by
OCA is a sheet and LOCA is the liquid version cured by UV light.
by
i use LOCA and let it cure under uv the light
by
Add a comment
Add your answer
shayne1542 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 94
