Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1500 Questions View all
sim contacts broken, whats the way to fix?
i got 3 iphones where the sim tray was inserted wrong. the owners tried to rectify the problem by removing the tray and in doing so the pins(sim contacts) were broken during the process. ifixit.com don't have the iphone 3g boards, help!!!
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
HI
you just need to buy SIM card connector on Ebay and change it.
You can find the guide on YOUTUBE.
Comments:
Could you link to an install guide?
by
Add a comment
Most Helpful Answer
Find an old unneeded cell phone that uses a sim card. Break off one of the copper colored sim card contacts on that cell phone. It looks like a thin strip of metal.
After taking off the face plate of the iPhone 3G:
Bend the contact into the shape of a semi circle or a smile and slide it into the slot of the missing (broken off) sim card contact on iPhone. If you make it long enough and bend it/curve it enough it will hold itself in place. Install the iPhone sim card tray with the sim card in it and make sure the contact you installed stays in place. The sim card pressing against it will help keep it in place. Put the iPhone back together and it should work.
I had similar problem on my iPhone 3G. The iPhone 3G was working when I gave it to my wife who took out the sim card to put it in her blackberry. I didn't realize she broke it until I went through all the trouble of updating the baseband to 6.15.00 running iOS 4.2.1. I used Pwanage and Untrasn0w and then kept getting a sim card not installed error. I read a post that mentioned the a sim contact is broken or the sim card tray is not depressing a type of circuit breaker that also tells the iPhone a sim card is installed. In my case the sim card contact was broken off. No sign of it in the iPhone. I did the above and am ecstatic. I had an old broken cell phone in the house, didn't have to buy parts and was able to do it in about half an hour taking my time.
BTW: This iPhone 3G also had the wifi problem. Not sure what fixed it. Might have been when I updated it to iOS 4.2.1. Wifi now works like it was never broken. I also disconnected and reconnected the antenna before I did the update but that didn't seem to resolve the issue. Maybe it was both the reseating of the antenna and the iOS update. Who knows. Good luck!!
Score 1
Add a comment
The way to fix it is to replace the part. If your sim card is broken then you need a new sim card. If the iPhone end is broken than you need a new iPhone logic board.
Repair guide here:
iPhone 3G Logic Board Replacement
Once you take it apart you can look to see if you might get lucky and just be able to carefully bend a pin back in place or something, but most likely you need a logic board.
Comments:
half of the pins are broken... can't find a 3g logic board on ifixit.com. any suggestions on where to purchase the board?
by
Add a comment
got the part from ebay..thanksalot!!
Add a comment
There are a few good tutorials on YouTube! "Repairing the SIM-reader of iPhone 3G. (The "No SIM" error")": http://www.youtube.com/watch?v=DFh7Vp1As... and "iPhone 3G Sim Connector replacement".
Add a comment
no i mean i can''t remove the sim card tray at all. How can i do this? i have tried paper clip and everything
Add a comment
Add your answer
frank99 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 20
All Time: 12,638
