Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
My iPhones earspeaker dont work after rear plastic change.what to do?
today i fix alone my broken iphone..(has broken rear plastic).before i fix it..all the hardware worked great without any problem.it was just the plastic.i try to fix it(change plastic with new one from internet).after 4 hours of repairing it.i finaly closed and i try to boot up the iphone.iphone started all works fine but the earspeaker dont work.i am happy because i fix it and sad because i cant hear any call any more...(hands free and loudspeaker work perfect!)... please help me..
Score -1
Add a comment
1 Answer
Chosen Solution
try reseating connector no. 3.it controls earpiece
3 Comments:
how to do this???
by
slide to power off phone then open iphone again-just to front display assembly and you will see connectors labelled 1, 2, 3. to access no.3 you will need to lift the first two. lift hinge on connector no.3 and slide out. then reverse the process. no 3 doesn't have to be in all the way to white line but you'll feel a resistance that it's in place (seated) then replace the other 2 connectors, replace screen and dock screws. power up and see what happens
by
ty very much i will try it!.if dont work again?should i buy the whole system #3? (earspeaker+sensors).
by
Add a comment
Add your answer
discoboy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,239
