Repair guides and support for LED, LCD, HD and other Vizio TVs.
316 Questions View all
Broken Cable Connection, Can I use MHDI?
The cable connection on my Vizio TV broke off. I have not yet found a tech to resolder it, not sure I can do it myself. As an alternative connection, can I get a Coax-MHDI converter/adaptor, and use MHDI port (to connect antenna.)? Thanks, Ed,
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Hi,
Firstly there is this info regarding co-ax to hdmi (I think that's what you meant). There is no such simple device You need something like a STB or PVR to convert the co-ax analogue input signal to the hdmi digital output signal. See link
http://www.hdtvsupply.com/coax-to-hdmi-c...
An easy temporary solution is to connect your aerial into a STB (set top box)or PVR (personal video recorder) if you have one, then connect to the TV from it either via HDMI (if it has it) cable or via composite video (red/white/yellow) cable. You then have to use the STB remote control for channel/volume selection, whilst the TV is just set on the correct input source and turned on/off and perhaps the volume adjusted to suit.
Score 3
Add a comment
Add your answer
Ed Minor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 82
