Why is my iPhone disabled for 24 million minutes
tried rebooting it and pluging into iTunes still no result.
@laxpro88 you will have to restore the iPhone since it is disabled. Couple of reasons why it is disabled are the most common reason is to many failed attempts on the pass code screen. Or if someone accesses your I-Cloud account from another device & change your security settings. If your phone is connected to a computer with out-dated iTunes this could disable your phone as well. You'll have to restore it. You must use the computer that you usually use to sync etc. your iPhone.
Make sure you have the latest version of iTunes installed and running before attempting to update.
Connect your iPhone to your computer.
Select your iPhone when it appears in iTunes under Devices.
Select the Summary tab.
Select the Restore option.
When prompted to back up your iPhone's settings before restoring, you can select the Back Up option.
Select the Restore option when iTunes prompts you. This is where you will lose all the information that is on your iPhone
Once the restore process has completed the iPhone restarts and displays the Apple logo while starting up.
Otherwise follow the instructions from Apple on here
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,527
