The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
577 Questions View all
Looks like I need to replace motherboard, yes?
I have a Samsung Galaxy S3 that won't power on. It was my daughter's and got submerged in water. I'm new to this and thought this would be a good exercise, so took out the motherboard in search of the problem, and I think I found it.
Check out the attached images of the motherboard, and especially the first one where I've marked what I think the problem is. Looks like some of the components on the motherboard are fried:
I didn't see any other obvious areas of damage, but I'm guessing that the whole thing will need to be replaced anyway.
So I think my next move is to order the Samsung S3 Verizon motherboard and install it by reversing the disasembly steps that I took to remove the damaged motherboard. Simple as that, or is there more to it?
Also, dumb question: what about the Android OS? Is it stored somewhere on the damaged motherboard that is going away, or elsewhere on the device? If somewhere else, I would think that there is no problem with swapping out the motherboard. But if it is on the motherboard, I have other questions (such as will it be present on the replacement motherboard, and if so, what version, and so on).
Comments:
The new board would come with a its own android os loaded on it, all the information for the phone is on the board of that phone.
by
Thank you for the info!
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I would try soaking it in some isopropyl alcohol to remove that corrosion. Let it soak for a few hours up to a day and than brush the board lightly with a toothbrush. I would than let the board dry for a few hours (maybe up to a day) to let the excess alcohol evaporate. I would try the board again after that. If it is still dead at that point I would try a new board. I hope this helps!
Comments:
Ok, thanks, I'll give that a try!
by
The alcohol got rid of that corrosion and the board is shiny-clean. But unfortunately, it still won't boot so I guess I'll try a new board.
by
Sorry to hear it didnt work! I figured it might be worth a shot!
by
It definitely was and it was a good learning experience. I did actually think the chips looked burned; I did not recognize corrosion. Now I know ;)
by
Replaced the motherboard and the phone works like a charm! Great experience, looking forward to my next repair job! Thanks for all the advice.
by
Add a comment
Add your answer
Darryl Whitmore will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 97
