Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
616 Questions View all
HDD won't boot fully.
I couldn't boot up my HDD on to my other MacBook pro, as it refused to unmounts after trying everything, plus sudo codes. Anyway I wiped it on another mac with an external hdd cable, got a bootable Yosemite usb done. However it would not set up OSX when my HDD was in my mac. So I then took hdd back out and tried to set it up external and Bingo it worked got a full working mac. However I cant transfer this hard drive back to my mac, as it only boots half way, I know I have done something wrong. Any ideas? The cursor line under the apple will only run up to the half way mark, and does not seem to be moving. I have plenty backups on another external HDD from time machine. I am wondering what to do now. I can work it with the external adapter, but I want the drive in the machine.
Regards
Comments:
did you tried the safe boot? try turning on the mac while pressing the shift key and then do repair permission that may help!!
good luck
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Replace the Hard Drive/IR cable with a new one from a 13" 2012 model.
Score 2
Add a comment
Add your answer
soundmanjohns will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 64
