Component accidentally pulled off motherboard
OK so while attempting to downgrade my ps3 to 3.55 using an e3 flasher, I was not able to get the blue lights to come up so I gave up and began to put the ps3 back together. When pulling the battery , I noticed two small components on the motherboard (which I will attach an image of at the bottom of this post) fall out. I was hoping this didn't completely break the ps3 so I put everything back together hoping it would still work but I was wrong and nothing is working in my ps3. I would like to know what could be done about this problem and if my ps3 can be fixed. Thank you.
Components: [IMG]http://i67.tinypic.com/31359wh.jpg[/IMG]
[IMG]http://i63.tinypic.com/6pypll.jpg[/IMG]
4 Comments:
Looks like some capacitors. Now post an image of where they were mounted on the board.
by
I will take apart my ps3 again soon. If they are capacitors, could they be fixed and would that definitely be the problem with my ps3? Thanks for the answer
by
You should be able to solder them back on if the pads are ok
by
Alright thanks I just need to find someone to do it for me I'd have no clue on what to do
by
Add a comment
