Improved second generation Google-branded tablet with a 7" screen.
98 Questions View all
Nexus 7 Device Charging Help
Device stopped charging. Replaced charging port and still wont charge. Lock screen does not indicate charging. Tried multiple chargers. Replaced battery and conditions remain the same.
Any advice?
Thanks
Score -1
Add a comment
Check you cable try a different usb charger some times the block from asus goes bad and would need replacing
1 Comment:
I have tried multiple chargers. Ones that work in other devices and it has no effect.
Thanks
by
Add a comment
the asus brick not the cable
3 Comments:
I no longer have an asus charger brick or cable. I have two other Nexus 7s and they charge with these other chargers. Can I even buy an Asus charger at this point? Should I try that?
by
yes ebay carries them cheap
by
asus sells the bricks with them because of certain amperage needed to charge the tablet not every tablet take the same amperage
by
Add a comment
Add your answer
pmcint01 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 116
