Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577 Questions View all
Touchscreen doesn't work after replacing digitizer
Hello,
I replaced the digitzer on my iPad Air as the screen was cracked pretty good. It took a long time to get the screen off as it was more like shattered in some places. After i put the new digitzer on, bought off of this website (not a cheap ebay knock off), I didn't seal it with the adhesive as i wanted to ensure the touchscreen worked properly first.
So i carefully put everything into place and nothing happened. i double checked my connections and tried again and nothing. However when i did move the screen to the open position, as i was going to recheck the connectors and cables again , it reacted as i was just barely swiping the screen when it's locked.
Is the digitizer bad? Are my cables hosed? What did I do wrong?
1 Comment
I heard other people having similar problems with cables being bent and unbent. Sorry, not sure what much else to say.
by
Add a comment
1 Answer
Chosen Solution
I know you said you double checked the connections. But, triple check them. It's possible you just don't have the connector all the way in there. If that fails, I would guess you've purchased a part, with a bad cable. I've seen it happen. Play with the display assembly and see if that's likely the issue
Score 2
1 Comment:
Thanks, ifixit sent me a new screen and it worked like a charm!
by
Add a comment
Add your answer
Jared Millirons will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 90
