Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
51 Questions View all
Start-up, engine running trouble
1996 honda accord won't start without a jump start (connected to another car's battery via cables), but engine immediately stalls, shuts off as soon as i remove (disconnect) the jumper cables.
Add a comment
Father's Day Gift Guide
Let’s honor more than our dads—let’s celebrate all the mentors who taught us how to fix.
Let’s honor those who taught us how to fix.
Chosen Solution
apelahama sounds like you have a bad alternator. Your battery is most likely drained because of not being recharged. Replace the alternator and charge your battery, then re-evaluate.
Comments:
Thanks for your suggestion s, I'll try this asap!
by
Add a comment
Most Helpful Answer
HI,
You have a flat battery (as you already know) but I'm suspecting that there is probably either low or no electrical power coming from your alternator. Even with a flat battery, once started the car should keep running because the alternator is supplying the electrical power.
In your case, check that the fan belt is not broken or loose. If it is replace it or tighten it, jump start your car and see if it keeps running, with the jump cables removed. If it runs, take it for a drive to put a bit of charge back into your battery, so that it will start next time
If the fan belt looks OK do the following.
If you have a voltmeter, connect the other car's battery with cables to your battery, do not have the other cars's engine running, start your car and measure the voltage across the your car's battery terminals, with the jump cables still connected. If you only read about 12V (you are reading the other car's battery voltage- not your alternator) the alternator is faulty (it is probably the regulator but that is inside the alternator anyway). It should read 13.8-14.5V approx.
If you have no voltmeter you need to get an auto electrician to check it out. If you have one close by, if you replace your battery with a charged battery it should get you there before it goes flat - maybe ( make sure that you have the lights, radios any thing electrical turned off, - to take the drain off the battery, it needs to power the car), or if there is a mobile auto electrician who comes to you or get it towed there.
Score 2
Comments:
Thanks for your help, at least i have an idea on where to start! I'll certainly do this and get back on outcome!
by
Add a comment
Add your answer
apelahama will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 122
