A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
232 Questions View all
What kind of micro rf coax connector is that on the motherboard?
I'm referring to the round black ones on the motherboard that seem to be next to every spring loaded connection to the back cover. None of them are in use and seem to be for testing or for using some kind of external antenna.
It does not seem to be an I-PEX connector to me (these seem somewhat smaller and shorter). Any idea on this one?
(I have a broken spring loaded antenna conector and I'm thinking of using this radio outlet as a workaround but I need to find the male counterpart.)
Thank you
Comments:
I found something. It seems to be a testing probe connector. MHF-SWxx, with xx being a size number, 18,20,23. To my understanding, there are no male connectors for these ports. Bad luck.
by
Add a comment
1 Answer
Chosen Solution
Mike H, I am a bit confused by which part you are looking for. I hope the parts you are looking for are the ones marked in the attached image. Those are Hirose Subminiature Coaxial Switch 1.35 mm High, DC to 11 GHz. MS-156C series. Those are available at places like this. If those are not the parts you are looking for, mark your parts on the image and post with your question. Use this guide for that.
Score 1
Add a comment
Add your answer
Mike H will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 83
