Why is Bluetooth is unavailable when I check profiler?
I replaced the dc in as well as the frame around the LCD; everything was a success however when I checked the profiler the bluetooth was no longer available. My question is where is the bluetooth antenna/chip or whatever it is on this computer? I have it open but im not seeing anything that would appear to be wires I forgot to connect. Thanks for any help
Ibook G4 1.33 14" A1055
Score -1
Add a comment
1 Answer
Chosen Solution
Go to this teardown and look in the upper left hand corner for the bluetooth board and cable: http://ep.yimg.com/ca/I/lovemacs_2119_29... The cables run right next to each other in the upper left hand corner and you may have disconnected something.
Score 1
1 Comment:
From this diagram does it look as though the antenna runs up the side of the lcd or does it stay in the upper case area?
by
Add a comment
Add your answer
mike36 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 893
