The white lights on my beats keep flashing from left to right?
So I got my beats brand new and they worked fine for the first day. On the second day, I used them for a bit and then whenever I switched songs, it would disconnect from Bluetooth from my iPhone. And no, there's no water damage. So I tried to update my beats using beats updater. It connected to my Mac but my update was "interrupted" and I couldn't get the headphones to connect to the computer again. I tried to reset my headphones but the white lights keep appearing to flash from left to right again and again. I tried using the optional phone microphone cable to listen to music and nothing would play. Hope it's not broken:( All I know is that the reason it kept disconnecting from my phone was because I didn't update the beats. But when I tried to, it won't connect to my Mac. The website said to reset them. And when I tried to reset it, it would reset and the white lights would keep flashing. They won't turn off. Should I let the battery drain out and try to turn it on again? Or is there another way? Thanks.
13 Comments
That's exactly what my beats did too. My beats are doing the exact same thing I can't do anything with them...
by Ryan Cook
This is the exact thing that just happened to me :(
by aidandaley1
Did you ever get an answer to this question? I'm going through this now.
by shaynadiego
I finally found the actual problem. The reason why the update is interrupted is because the beats drivers is not digitally signed. On windows you must remove the restriction of windows blocking the drivers that are not digitally signed. For example on windows 10:
Click the Start menu and select Settings.
Click Update and Security.
Click on Recovery.
Click Restart now under Advanced Startup.
Click Troubleshoot.
Click Advanced options.
Click Startup Settings.
Click on Restart.
On the Startup Settings screen press 7 or F7 to disable driver signature enforcement. Your computer will restart and you will be able to install non-digitally signed drivers. If you restart your computer again the driver signature enforcement will be re-enabled. Then you run the beats updater while the headphone is on update mode (flashing light left and right) and blam! It will work and continue the update. Windows seem to block the driver because its not digitally signed by apple.
by Emil Munoz
Emil, genius you are, thank you. I was on the chat with apple for two hours and they were finally going to send me a box to send beats back to them for fixing. Thank you again.
by David Flores
Show 8 more comments
