Complete how-to and replacement guides for the original iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPhone XS, and iPhone XS Max.
32291 Questions View all
Question Closed
How to Recover Lost Contacts, Photos from Water Damaged iPhone?
If you unfortunately drop your iPhone into water and you want to recover lost data of iPhone, please tell us what the idea you want to share to other uses. Thanks!
Score 1
Comments:
How to rescue contacts photos from water damaged iPhone?
When data in it lost, you are advised to turn to iPhone Data Recovery. With this cutting edge design, it is available to retrieve all your deleted contacts, messages, photos and so on. It is available to retrieve your files via your iOS device, iTunes backup files and iCloud backup.
Hope this can help you , best regard!
by
Water damaged your iPhone and want to get data back?Don't worry,this iPhone Data Recovery tool ( http://www.android-iphone-recovery.com ) will help you recover lost data back for you,if your iPhone is damaged with water.
http://www.android-iphone-recovery.com/r...
by
First please try your best to dry your iPhone.
When your iPhone was water damaged, don't use it as normal, it may get your iPhone overheating later and damage your iPhone's hardware. Just get your iPhone away from the water and power it off immediately.
Don't try to dry your water damaged iPhone with a hair dryer or other external drying machine.
If the water damaged iPhone can't be repaired and you can't get the data on it with the worst result, any possible solution to retrieving the data? The answer is positive. Here we’d like to introduce the best iPhone data recovery tool- Brorsoft iRefone for Mac, which enables you to extract all data from the backup file and you can selectively preview and export whatever you want.
http://recover-iphone-lost-data.over-blo...
by
Add a comment
MacBook Battery Fix Kits
Starting at $69.99
Buy Now
Starting at $69.99
Buy Now
Drying a water damaged iphone is actually the worst thing you can do. This will cause the metal on the motherboard to begin to corrode and rust.
Add a comment
Unfortunately drop your iPhone into water, what will you do first? Absolutely, get it out from water and then dry it off at once. How about the data on water damaged iPhone? You will lose them forever? Of course not, there is still great chance for you to get back the data as long as you have this iPhone iOS Recovery tool.
With download this free trail version iPhone iOS Recovery software, you can easily Rcover Lost Data from Water Damaged iPhone 4/4S/5/5S/6/6S/7/7S/Plus.
Score -1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 889
