Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
water-damage: Doesn't turn on after isopropyl bath
Is there anything else (cheap) i can try?
Add a comment
Chosen Solution
Ok, so you cleaned the phone. Did you try swapping out parts? Like the battery? Or the lightning dock?
Score 2
2 Comments:
No, not yet. Is there anyway to identify parts that might have been fried?
by
The battery needs to be replaced. I would remove the battery, after the cleaning, then put the display assembly and lightning dock back on. Then plug the phone in. It should power on, but you'll likely just see the apple logo. This will tell you if your lightning dock is working
by
Add a comment
You need to remove the EMI shields and clean it properly, then replace the battery.
You HAVE to replace the battery, there's no cheaping out on that.
Remove the shields and put the board under a microscope and examine anything out of place
Score 2
1 Comment:
thanks, I'll try that.
by
Add a comment
Hello,I am Chinese.你的手机进水不开机么?可能是主板问题。
Add a comment
Add your answer
Ploki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 155
