Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
157 Questions View all
Hardrive or hardrive cables?
I took my iMac into the Apple Store because of the dreaded flashing file with question mark. At the Apple Store they ran diagnostic. I was told it could be the hard drive or the cables to the hard drive could be loose or need replacing.
I used fixit guides to open up my iMac (thanks for great instructions and videos) I cleaned my fans got all dust out with a soft toothbrush, however I found the hard drive cables were connected properly.
Now my dilemma, before I replace the hard drive is there a way to test it to see if it's really dead? Is it cheaper to replace cables, should I do that first? Is there a device that can tell you while you have the hard drive out if it's bad. Or, is there a way to connect it to another Mac to see if its' good?
I have a newer Mac mini with an i5 quad core. Just want to know and also need recover any data from that old HD if possible.
Thank you.
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
1 Answer
Chosen Solution
I have not seen the cables go bad on an iMac.
Here's and adapter to externally test the drive: Universal Drive Adapter
You cannot test it while in the iMac if it can't be seen. You could try it in Target Mode by hooking up to the Mini, but I doubt it will see it.
Universal Drive Adapter Image
Product
$24.99
Score 2
Add a comment
Add your answer
Melissa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
