Das Fahrzeug wird zu heiß
Mein BMW 315i compact wird schon nach ganz kurzen Strecken viel zu heiß und kommt kurz vor den roten Bereich. Den Kühler habe ich schon ausgetauscht und am Thermostat liegt es auch nicht hat sich rausgestellt. So langsam bin ich sehr am verzweifeln.
Hoffe es gibt dafür eine Lösung auser das der Motor kaputt ist
Online Translation
The vehicle gets too hot
My BMW 315i Compact is too hot after quite short distances and comes just before the red zone . The radiator I have already replaced the thermostat and it is not out has found . So slowly I am very despair .
Hope there is a solution other than that the engine is damaged.
Have you checked your fan as well as the fan relay and switch? What year is your BMW? What do the spark plug faces look like? any indication that you are leaking antifreeze in the combustion chambers?
by oldturkey03
Hi,
With a cold engine, take off the radiator cap, run the engine. When the thermostat opens you will see the coolant moving in the radiator. This tells you that your thermostat and water pump are both working. If it doesn't move and your temperature gauge is going up it is either that the thermostat or the pump is not operating. Be careful, as the coolant heats, it expands and may start to overflow out of the open radiator.
by jayeff
It is exactly as these comrades are saying I did the procedure and it worked.
by henrydeep
