Non-Unibody, Core Duo & Core 2 Duo Processors
452 Questions View all
Size of logic board in a1151 and a1229 identical?
Can you put the logic board of the a1151 into the a1229's body?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
You would need to replace a lot of parts, as the connectors on the A1151 are different from those on the rest of the original 17" MBP models. Also, the keyboard and left I/O board, while identical in form factor, are actually incompatible.
Score 3
Add a comment
Hi Ben
to follow up on the discussion, if I want to change the A1151 board on my MBP by a 1229 (or 1261) board, I will also need to change:
- the left/right fans (or connectors)
- the left/right thermal sensors
- the I/O board
- the keyboard
is there any other parts?
thank you
Add a comment
Then try this one. It says compatible on MacBook Pro 17" Models A1151 A1212 A1229 and A1261
Add a comment
Add your answer
marius will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,303
