Why will it not advance past wash cycles?
I run the dishwasher it goes through normal wash, water miser and light wash, then shuts off! I have tried manually advancing the timer but it still does nothing!
Comments:
So the next step is drying on your machine?
by
I think it is rinse right??
by
it is drying
by
right now it won't advance or do anything. If i press the cancel button, which is intended to drain all the water and reset the unit, i here the unit trying to drain the water but the blinking light comes back on and the unit doesn't do anything else and is not reset
by
are you still there
by
Add a comment
1 Answer
Chosen Solution
Most Frequent Causes for Dishwasher not drying dishes
Cause 1
Vent
The vent might not be opening properly. As the dishes are drying, many dishwashers use a vent to let out the hot, steamy air generated during the rinse cycle. If the vent does not open properly, the dishwasher will leave moisture on the dishes. Check the vent to ensure that it is opening properly.
Cause 2
Vent Fan Motor
Some dishwashers use a vent fan motor to help dry the dishes at the end of the cycle. If the fan motor is not working, the dishwasher won’t dry the dishes properly. To determine if the fan motor has failed, test the motor for continuity. Also, try turning the fan blade by hand to ensure that it spins freely. If the fan motor has burned out or the fan blade won’t turn smoothly, replace the vent fan motor.
Cause 3
Heating Element
Some dishwashers use a heating element to heat the dishwasher during the drying cycle. If the heating element has failed, the dishwasher won’t dry dishes properly. To determine if the heating element has burned out, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Score 3
Add a comment
Add your answer
Lucy Loo Hoo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 45
All Time: 530
