The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
295 Questions View all
Why is the machine leaking water from under the drum when spinning?
  1. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)
Add a comment
1 Answer
Chosen Solution
Cause 1
Drain Pump
The drain pump pumps water out the drain hose. If the drain pump is cracked or damaged, or if the bearings are worn out, the drain pump may leak water. The drain pump is not repairable—if the pump is leaking water, replace it.
Cause 2
Tub Seal and Bearing Kit
The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings. This can cause the bearings to fail. For this reason, if the tub seal is leaking water, replace both the tub seal and the tub bearings. Be aware that this is a complicated repair and will require disassembling most of the washer.
Cause 3
Tub Seal
Score 1
Add a comment
Add your answer
edgar martinez will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 47
Past 30 Days: 205
All Time: 1,853
