Water dispenser randomly stops working.
My water dispenser acts like I has a mind of its own. It will work fine for weeks or months, then stop out of the blue. I can check it a few times a day then say a week later it will work again without any changes to the settings of the refrigerator at all. A new filter does not change this and the ice maker continues to work the whole time.
I know that low water pressure or icing of the water inlet tube can be factors, however I can not see these two things being at fault as I do not defrost the line and when the dispenser works it distributes water normally.
My guess at this point is maybe the door switch on the bottom of the freezer door has a mind of its own?
Thoughts are greatly appreciated!
3 Comments
I have a G.E. side by side that does the same thing and I'm searching for a solution also. Can anyone shed some light, please?
by Becky Slightom
I have this problem also.. I have replaced the dispenser control panel and the dispenser lever switch, but neither resolved the problem. At times, the green selection light for water, crushed ice, ice cubes, etc. just disappears and then re-appears later. I am assuming this is an electrical problem somewhere, but I don't know what else to check.
by Michael Lee
I fixed this problem by adjusting the pressure setting on the house water supply. Replacing the filter may have triggered the issue by introducing more resistance to water flow. In my area, the water pressure from our provider varies. In the fall, sometimes I need to adjust the water pressure lower to avoid banging noise from pipes after water usage.
by Kenneth G Seewald
