The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3787 Questions View all
iPhone 5s lines when only LCD connected
Hello,
I just replaced a iphone 5s screen, but now there are vertical lines on the screen. I tried other lcd's and there are giving me the same problem.
Why are there vertical lines when only the LCD cable is connected? FPC connecter of the LCD?
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
I fixed my problem now: On my case there were 2 problems:
1. Damaged touchscreen connector
2. Lose contact in the ribbon flex of the lcd itself.
Add a comment
probably the fpc connector on your motherboard
check for damaged/bend pin or dust
and clean the conector maybe there is some dirt/oil
Comments:
Did that already, I connect ONLY my LCD flex to the motherboard. It still giving lines, There is no visible damage on LCD fpc, but there is damage on Digitizer fpc.
So the question? is it FPC digitizer, or FPC lcd?
by
Add a comment
in this case if the FPC on your mother board are fine
all you need is to order a new LCD assembly
it will surely cost more to repair the fpc on a lcd assembly than buy a new one
Comments:
But I already tried like 3 new LCD assemblies. Which are giving the same problem.
by
Add a comment
I'd also like to know the answer to this. There is no visible damage to the FPC Connectors on mine... They have been thoroughly cleaned with alcohol and good working screens tested.
Update (02/05/2016)
It's the u3 display ic.
Add a comment
Add your answer
Job Wintjes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 124
