A collection of guides and support to help with washer repair.
3468 Questions View all
Not spinning or agitating, but the water does drain
Hi,
I have the 13kg top loader, wobble technology washing machine. The machine stopped agitating and spinning. We replaced the motor, but it is doing the same thing. This machine is driven by a belt.
Please advise what the problem is?
Samsung Top loader WA13F5S2
WA13F5S2UWW/FA
Score 1
3 Comments
I have same problem. I know for sure it is not the gearbox, and I replaced the PCB, I am stumped at the moment.
by
frans, post your question as a question, not a comment. Include make model and all pertinent info, are there any codes, etc. etc. and what you have tried.
by
My motor switch on immediately when switch on and the wobble piece run even before i push the play button
by
Add a comment
1 Answer
Most Helpful Answer
Cause 1
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 2
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Score 4
6 Comments:
Machine washes but does not spin
by
Charles this is usually the lid switch
by
Lid switch OK. What now?
by
Lid switch OK. What now? Replaced 250v 12 megfarad cap. Also manual
checked motor turns clockwise and anti clockwise
by
Still awaiting your answer to my question?
by
Show 1 more comment
Add a comment
Add your answer
Jolene will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 4,850
