My HMDX Jam Plus won't turn on. How do I fix this?
I left the speaker plugged in overnight but I still won't power on. When I plug it in the charging light doesn't light up.
Hi,
Have you tried a different charger? You can use a USB cable to connect between the speaker and a working PC and see if the charging light in the speaker turns on. If it does the charger is faulty. If not, first try a different USB cable, in case the first one (if you used the one from the power adapter) is faulty. If the light still doesn't come on, you either have a faulty charge circuit in the speaker or a faulty battery
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 7,381
