The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
525 Questions View all
Question Closed
Will turn on and run perfectly and then shuts off.
My phone will power up and run and then randomly shut down. When it is on, it works fine. After it shuts down, it will not recognize the power button. Battery is fine. I have restored and the issue has not been fixed. In order to turn it back on, i have to remove the battery and reinsert it. However, this does not always work.
Add a comment
Chosen Solution
Before sending it away for micro soldering try this it has been working for me in repairs lately
https://www.youtube.com/watch?v=pqBgbN8N...
But if this doesnt work your best bet for micro soldering is @jessabethany not sure if she does android or not but have seen some of her work on video and definitely knows what shes doing. If you click on he link it will take you to her page and you can contact her from there
Score 2
2 Comments:
The video did not fix it but the video that followed the one you linked here did. Basically all I did was tap my phone on the power key side enough to apparently do whatever was wrong with it. It has been on for 15 minutes now. That's the longest its been on for a long time. Thank you...indirectly?! lol
by
I know the video your talking about and be careful not to tap to hard. Your power button is the issue and jessa is probably your best bet to fix it when it does finally go
by
Add a comment
Most Helpful Answer
It's your power button. It needs to be replaced. Technically it's an easy micro solder job. But, it is micro soldering
Score 2
2 Comments:
Can it be mailed in to be fixed (do you fix this issue) or would it be better to take it to a local phone fix it location?
by
I don't have a mail in service. But, Jessa Jones at iPad Rehab does
by
Add a comment
iMedic is correct it's a defective power button that needs to be replaced. It's a very easy job if you know how to micro solder.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
