Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
874 Questions View all
Can we buy somewhere the wifi/camera/Bluetooth cable?
I found a screen replacement for my laptop, but it appears it's 2012 model, it works fine, except the plug for the camera wifi Bluetooth isn't the same on the different model, where could I buy the 2009 cable to reconnect it to the right hardware?
Update (12/12/2015)
OK,yeah thanks, I did realise it will be complicated when I disassembled it, I watched the vid from ifixit to see the wifi antenna replacement, still tried, but then realised, that anyway cable go behind the screen, so one or the other I would have to dissasemble the screen and I'm not equipped for! Plus just what you told, it's not feasable anyway!
Well I got to sale my screen now! Do you know then if this model 2012 is compatible with other 15" model?
Do know what to put in my announce to sell it! Because it seems the connector cable are very similar in model 2014 and 2013, even though it's from a 2013, I think they are all retina but they might still be compatible!
Comments:
I would just post the Apple part number the original seller sold it to you by.
by
Add a comment
PC Laptop Batteries
An easy fix for a big power boost.
Shop Now
PC Laptop Batteries
Shop Now
1 Answer
Chosen Solution
Ouch! Not so simple!
The problem here is the 2012 model has the AirPort mounted on the upper case. Review this IFIXIT guide: MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement. The older 2009 has the AirPort located in the clutch cover. Review this IFIXIT guide: MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement.
Basically these are very different lid assemblies. It's best to return the part and get the correct part than trying to force fit the AirPort and its connections into the other lid. Sorry ;-{
MacBook Pro 13" Unibody Mid 2009 AirPort Card Image
Guide
Difficulty:
Difficult
MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Image
Guide
Difficulty:
Moderate
20 - 30 minutes
Score 3
Add a comment
Add your answer
tregouetsylvain will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 108
