A collection of guides and support to help with washer repair.
1882 Questions View all
Machine not working , Error dE
Although the lid is closed and the magnet attached to the lid is intact, the door open error message (dE) is displayed and the machine (LG fuzzy logic model no. T6515TDPT01) stops working after taking two /three turns in wash mode. I seek help from you guys to fix the problem. Thanks
Score 3
Comments:
Check to make sure that the connector coming from the switch is properly seated on the circuit board.
by
Add a comment
Most Helpful Answer
Might be the magnet, usually the magnet pushes this switch the shows the door is closed. Hard to explain. Do you happen to have pictures?
Score 1
Comments:
I shall fix a stronger magnet and shall see if it works.
by
Add a comment
Power off the machine and unplug it if you receive the error mid-cycle or at the end of the cycle. After five minutes, restart the machine and try to open the door again.
Wait about a minute for the door to unlock if you paused the machine during a cycle. In this situation, the locked door and appearance of the DE error is merely a safety precaution.
Score 1
Comments:
Simple and great solution!
by
I could not get you dear gillrois. plz explain elaborately.
by
Click on the link for troubleshooting LG washer with error code DE. Hope this help Immi.
http://www.ehow.com/how_7850983_troubles...
by
Add a comment
Add your answer
Immi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 141
