"Battery Temperature too low" when charging after water damage
Hello, my Galaxy S6 Edge shows "Battery temperature too low" when trying to charge, doesn't matter if USB or inductive. It had contact with water so I think this might be the reason. I checked the temperature with an app and it always shows -20°C. Does somebody know what to do? I have already repaired some other phones but mostly just Display replacement or something like that. Do you think changing the battery would help? I also read that there's a temperature sensor but I can't find any replacement parts for that one.. Thanks in advance.
6 Comments
hi.i have 13 years of hardware experience in cellular industry.just change the charging flex cable or charging pin on it.thats it.
by Atiq Ur Rehman
This has also happened to me. I have tried with different cables and have even tried wireless charging but this hasn't helped. I can't take the back off to remove the battery and don't know what to do. Please help!
by ella-hart
cable must be changed.wireless will not help untill charging flex cable is changed or disconnected.we are based in goodwood.40 to 60 mins max to fix it.
by Atiq Ur Rehman
I changed cables and battery but still same error exist. plz help
by Muhammad Adnan
Change the IC of your phone. Hope..! It may help you. May be ur phone IC is dead that's the reason your phone is not taking charge and showing error.
by Rumi Basumatary
Show 1 more comment
