Disassembled and reassembled, now having charging issues and more
Greetings,
I recently got an iPhone 5 (not a 5S) and was told by the person I got it from that I need to open it up and clean out the camera, because it has a lot of debris. So I found this guide iPhone 5 Rear-Facing Camera Replacement and went to work. By step 27 I realized that I didn't need to get that far just to clean off the camera. *facepalm* So I cleaned off the camera and put everything together. I now have the following issues:
- Mophie case now causes "Device is not certified" error message to appear
- When Mophie case is plugged in and powered on and/or connected to wall charger, the phone will turn on and off incessantly.
- Original iPhone charger will work, as long as I plug it in a certain way. If the charger is turned "upside down" it will cause the "Device is not certified" error message and power cycling.
Your help is appreciated as I am at a loss. Thanks in advance!
