Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
292 Questions View all
LCD Proximity Sensor Location?
I recently had an issue with my LCD panel and I thought it may have been the LVDS cable but it ended up being the panel itself that is faulty.
I have taken the iMac into an Apple Store where they ran some hardware tests - turns out the LCD Proximity Sensor has failed and the internal fan is running at a higher speed.
Is the LCD proximity sensor on the logic board or is it part of the LCD panel?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
The LCD Proximity sensor is the small 4 wire cable going from the LCD to the Logic Board seen here https://d3nevzfk7ii3be.cloudfront.net/ig... It routes behind some tape located on the back of the LCD to a small PCB that is adhered. If you want to replace it http://www.powerbookmedic.com/Intel-iMac... (Careful their returning through them isn't the greatest experience)
Please remember to adhere to all safety and ESD precautions.
Score 1
Add a comment
so if I am to purchase another LCD panel the proximity sensor is part of cable/board on the LCD itself and not the small input connector on the logic board?
Comments:
It is a stand alone sensor that connects to the logic board via a cable, so it could easily be replaced. It is adhered to the back of the LCD. You can remove it easily if needed. :)
by
thanks for your replies Shmajay - appreciate you taking the time to explain
by
Add a comment
Add your answer
Shaun will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 37
All Time: 744
