The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3535 Questions View all
Can you tell me what these components are please?
Hi, I was swapping out a housing and doing a glass-only repair on my own iPhone 5s, and I have damaged 2 components on the board.
I have found a schematic and I can tell you that one is FL11 - is this what is causing the battery percentage to not work and the phone to restart while charging?
The other that is missing - L7 - next to the dock connector - would this cause the left channel of the headphones not to work.
Those are the only 2 faults I can find with the device now that the LCD is repaired.
Can anyone tell me if its an easy fix (for someone competent at micro soldering - not me) and what each component actually is - possibly with a link to buy.
All help is much appreciated.
Comments:
Also, would either of these components being missing cause the iPhone to bluescreen and reboot?
by
Add a comment
1 Answer
Chosen Solution
martinjmcinnes FL11 is a 120Ohm 210mA filter bead in a 01005 package. "is this what is causing the battery percentage to not work and the phone to restart while charging" that is correct. You'll need it. L7 is a 80ohm 1000mA 25% Ferrite Bead in a 0201 package. You are corrector about the Left headphone output on that one. A TDK MMZ0402S121CT000 would be a suitable replacement. Available at digikey. For L7 a Murata BLM03PX800SN1D available at Mouser is a suitable replacement.
Score 1
Comments:
Nice one! - 17p and 9p for parts on Mouser - whopping £12 delivery charge. Will need to try and track some down in the UK
by
Add a comment
Add your answer
martinjmcinnes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 139
