2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
406 Questions View all
Battery Change, requires regluing?
Looks like it takes some effort to get the batteries out but would you need to reglue it after you remove it? What happens if you don't reglue? Thanks
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
If you use a little Methanol Alcohol along the gap of the case and the battery it will break the adhesives bond so you can remove the battery.
Apple uses a glue gun to attach the battery. In their newest iPad system they changed to 3M adhesive tabs which I think is a cool idea! iPad Pro video. I'm wondering it these would work here as well. Otherwise you'll need to clean off any remaining glue and use glue gun adhesive again. Lastly, you must hold the battery down.
Score 2
Add a comment
Add your answer
Breaking80 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 106
