The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3318 Questions View all
Continually searching for network with/without sim
I already reset network setting
Already turn off and on the iphone with or without sim
Already checked the date and time
Wifi is connected
I already put mu sim into ipad and in ipad the sim is completely fine but when i put back into iphone it is still the same..still searching
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Tap Settings App > General > About > scroll down and see if there is IMEI #. If not, then the iPhone has major fault.
Score 2
Comments:
What should i do after that??what if there is no IMEI??can it be fix??
by
Add a comment
First things first. Check and see if something else can connect to your wifi signal. Let's assume it's not your wifi. Try toggling airplane mode off and on. Try forgetting your network, then find it again. Do a force restart. Try updating your iOS. There is one other trick that involves overheating your phone, with a heat gun or blow dryer, and then putting it in the freezer. But that's kinda like eating pop rocks and drinking soda. If these other things don't work. I would guess the wifi module needs to be replaced
Score 1
Add a comment
Add your answer
nurzafirah01 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 131
