Is my left-IO-Board broken?
Hey there,
my MBP stopped working propperly, beause of a short-cuircuit. Since then only th ports on the right site send signals. On the left side nothing works at all (no charging, no usb, no sound). These are all things that get their power supply from the left-IO-board.
Even the Power-Adapter and the Battery got f****d.
Since that day the touchpad aswell doesnt work at all. My question is, if it make s any sense of getting L-IO-Board , beacuse i couldnt find out if the touchpad gets the power from there too.....
ohterwise something is broken real bad i guess...
cheers
Add a comment
1 Answer
Chosen Solution
I suspect you have a bigger problem here.
Given on what you are describing you may want to think about getting a newer system then investing too much in this one. Parts are starting to get scarce and this system does have a known GPU issue. By the time you fix things something else is sure to fail. Sorry:-(
Score 1
Add a comment
Add your answer
Markus Offermann will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 117
