Why will my battery, which is brand new, not take charge?
My DC adapter will not charge my new battery.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Kathy Rossiter if your new battery will not take a charge, you first want to check your charger. Use a multimeter and check the contacts for proper voltage. If the charger works as it should, ask the vendor to replace the battery. Just because it is new to you does not necessarily mean it is new. It may have been discharged below the threshold of taking a new charge. Sometimes those batteries can be "woken up" by using a 9Volt battery and connecting +-+ and - to - from the 9Volt battery to the camera battery for a few minutes.
Score 1
Add a comment
Add your answer
Kathy Rossiter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 15
