The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
120 Questions View all
Where can I get this a 32G Motherboard if any?
So I've got this tablet from a friend who "ruind" it by breaking a tiny part that holds the lcd cable so it wouldn't move that black clip that makes it stick is broken so I thought I might buy a new motherboard, the thing is this tablet is 32G and the only available motherbaords at ifixit for this tablet are the 16G.
I was trying to find on other websites without a success, I love ifixit and I was wondering maybe if someone here can help me, or give me an idea to where I should look.
Basically I've got a tablet that potintioly is "working"
I can't turn it on/off or at least I can tell + screen is off, I think it's related to the motherbaord and the black clip that keeps the cable in it's place that broke it.
After I'll replace the Motherboard I'm planing on installing OEM Rom
Add a comment
1 Answer
Chosen Solution
Just a thought. Could you just place a small blob of Silicon sealant (neutral cure), to hold the lcd cable securely in place? First see if the tablet will work with the lcd cable held in postion. If so, support the cable in the desired position while applying the silicon and then allowing it time to "cure"- even up to 12 hrs. Suggest you do not allow tab to remain on whilst applying silicon. More because something might slip while you are applying it and there will be less consequences if it is not turned on. Bit hard I know because you have to know that the cable is in the right position when applying the silicon, therefore it has to be on. Basically saying take it slow and carefully. Also here is a link for a replacement cable, I don't think it has the holding clip though. (Just in case you try my suggestion and somehow, don't know why it would, it affects the cable.)
Score 2
Hi thank you for your quick answer,
I decided not to waste time and take a risk and ruin the cable itself so I ordered the motherboard of the 16G I presume it does not matter.
Hopefully it will solve my problem ^_^
Add a comment
Add your answer
DocBrown will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 134
