Repair guides and support for the third generation of C/K pickup trucks.
21 Questions View all
Gas mileage really sucks?
It sucks gas I know it's a 350 with full time four wheel drive but I should be getting more than 4 mpg
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I'd take it in to an AutoZone and get a free computer readout to try to see what's wrong. Also see if the the four wheel is engaged all the time.
Score 1
Add a comment
Most Helpful Answer
Hi,
Maybe you should consider a tune up for your vehicle. Google how to tune my chev pickup.
Score 1
Add a comment
you can save serious gas mileage get a set of warn hubs so you can technically be running 2 wheel drive you can unlock and run too high also it's probably a good idea to tune up your engine spark plugs fuel filter oil change air filter PCV valve check your timing. It also might not be a bad idea if you have a full-length exhaust maybe not in good shape to possibly put a set of good free flowing headers on there. also rebuild your carburetor and make sure you have it dialed just right.. Also don't forget to change your cap and rotor
Add a comment
Add your answer
Ben Wright will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 102
