Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
126 Questions View all
Telephone Network (GSM) unavailable after display replacement
Hello, I wanted to ask you if you had already encountered a similar problem.
Yesterday I replaced the display of my one plus one following a fallen, display correctly replaced but when I went to turn it on to test the touch sensor I didn't realize a problem, the cellular network could not connect with the device, by going to network operators seeing my carrier (Vodafone) with preference 4 g lte but when I select the network, after a long wait out the following message "unable to connect to this network now, try again later"
Can you tell me if it is a software problem or closing it I might have damaged the antenna of my device? Let me start by saying that the networks are detected correctly, lacks the binding ... thank you very much for any answer
Add a comment
MacBook Battery Fix Kits
Starting at $69.99
Buy Now
Starting at $69.99
Buy Now
1 Answer
While I've never serviced OnePlus One phones, you may have forgotten to plug in the antenna after you replaced the display. It's common to need to fiddle with the antenna connection during screen replacements in most smartphones.
This replacement guide may be what you have recently performed.
CTRL+F the keyword "antenna" and read what a couple of comments have to say about the antenna.
Hope this helps!
Add a comment
Add your answer
Marticus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 117
