Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1647 Questions View all
Question Closed
freezer isn't keeping things froze water leaking around bottom of item
Freezer won't keep ice frozen water is leaking out of the bottom of the fridge what might be but the problem
Add a comment
Chosen Solution
Check the seal in the freezer door
Score 4
Add a comment
Has the fridge got a temperature control for the freezer section? Possibly set too low?
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 81
