The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3534 Questions View all
What is the purpose of this cable/connector?
Hi,
What is the purpose for this cable/connector?
I was trying to replace my battery and unplugged this FPC and when I plugged it back it snapped 4 of the pins...
Is this fixable or am I screwed?
Comments:
Unfortunately my screen is broken and I have a replacement waiting delivery. When I connect my phone to the charger, it heats up a lot and keeps either vibrating or making the charge noise...
by
Also the cable is okay, the dock it self has broken pins.
by
Add a comment
Chosen Solution
You could send out to have to connector replaced, or you could live without it.
You'd need to prompt your phone to boot by plugging it into charger, then control the volume/mute/power functions from assistive touch
Score 1
Add a comment
Most Helpful Answer
It is power button flex, which I believe controls power button, mute vibrate and volume buttons and light.
Score 1
Add a comment
what happens when you connect the a new cable, you might find some functions work depending on what connections were damaged.
I agree with the answer above though, live without it.
Add a comment
This is responsible for lock button, volume control, vibrate control and rear microphone. I would send the board of and have that replaced. If you are in the stated and can post I would recommend: http://www.mendonipadrehab.com/
Jessa is the best at board level repairs
Add a comment
Add your answer
leonidazz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 103
