Caffitaly System S04 how to get inside?
I did open the simple parts, botom part and get into engine but no way to go further .there is also a part am looking for. if you have an idee how to thank you
How did you get the bottom off? I cant even get that far! There is a strange screw at bottom which I dont have a screwdriver for.. :(
The strange screw needs a special manufacturers implement. I improvised using a small screwdriver and a large nail to insert into the two depressions in the screw. I eventually managed to rotate the screw and undo it. However taking the main body apart and releasing the deep set screws inside the chamber is virtually impossible. If you need to view the plumbing in this section - bad luck-Destroy the machine and get a new one!!!!!!!!!!!!
tell me what is the problem with your machine? maby i can send you a video how to fix it.
It won't prime
It's brand new and won't prime just is buzzing then the buzzing stops but still won't prime
Has anyone managed to get inside this coffee machine? I have undone most of the screws I think hold the casing together but it still won't undo. Does the handle at the top need removing?
This is two years ago, but I eventually opened up the machine, found the part that was damaged and replaced it. The machine worked, but there was still some leakage.
Caffitaly machine s14 leaking water from the bottom when I try to dispense water for tea or coffee. Has anyone found the issue with this? Is it an elbow issue inside? Many thanks
this is common, poor design.
I added a piece of pet bottle plastic so the runoff went over the gap between the pod catcher tray and the internal walls of the machine... no more leaks
My caffitaly machines handle has been forced down by a friend…there was a pod stuck inside besides the one she tried to put in and now the handle keeps popping up and the machine won’t work can this be fixed?
It could be fixed, but you need to open it. Don't pay to have it serviced, it's not worth the money.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,800
the machine does not suck water
by abadi
Can you back wind here a bit.
What was the problem before you started, and what part or assembly are you trying to get to?
by Dan
