Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
No display on handset after teardown?
I bought a cheap 3g for a friend of mine. Battered, beaten, and with a shattered screen.
I ordered a new LCD, digitizer and casing for the phone. As the LCD and digitizer arrived first I fitted those last week. No problem, the phone worked great, aside form the very tatty rear housing.
The part arrived today. Stripped the phone and reassembled it in the new housing. Worked fine agin, except the dock connector was at a slight angle in the new housing. Stripped it down to reposition it slightly, reassembled it and..... nothing.
The phone is recognized in itunes, and then on the vibrate on off button works, so I know the phone is working, just not kicking out any display. I tried the old LCD in it. Although cracked it would have at least lit up but nothing is being displayed though that, so I can only assume its an issue with the logic board outputting a display.
Does anyone have a solution or remedy or any suggestions to what I should try?
Thank you.
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
Try this. Same thing happened to me last night. What happened was that I took the connector off the board while the phone was powered on.
Go into recovery mode by pushing the Home Key and Power Button simultaneously. Once you hear the rings, it should turn on. Either that or you got a busted LCD.
Score 2
Add a comment
Thanks for the info Nelson, mine is working now but i broke the lcd on disassembly, at least its still working.
Score 1
Add a comment
Add your answer
Huw will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,876
