The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
16 Questions View all
No air from floor vents or defroster vents, only front vents.
I get good heat and air conditioning from my front vents, but when I select floor or defrost vents, the air still only blows from front vents. What's the problem and how do I fix it?
Score 1
Comments:
It's a 2008 Ford Escape.
by
I have the same issue on my 2008 Ford Escape.
by
Add a comment
1 Answer
Chosen Solution
You will need to check the vent actuator to see if its functioning. The actuator is a controller that opens and closes the flapper that direct the airflow from the fan . This is under the dash on the passenger side . There are two types of actuators , electric or vacuum . If its electric you may simply have a blown fuse or it could be a bad actuator, if its vacuum you would need to look for leaks in the system. which could be in the lines to the actuator or the actuator itself . Hope this helps
Score 4
Comments:
What fuse? I looked at the manual
by
Add a comment
Add your answer
S Thompson will be eternally grateful.
Past 24 Hours: 30
Past 7 Days: 295
Past 30 Days: 1,303
All Time: 11,854
