The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
126 Questions View all
Replace LCD without removing digitizer?
I have a Samsung Galaxy Tab 3 7.0. The LCD is shot but the digitizer/screen is fine. Can I replace the LCD from the back with out having to un-glue and re-glue the digitizer? Trying to avoid that hassle if at all possible. Can someone post instructions for replacing the LCD only?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Unfortunately no. The mid frame holds the LCD in a bit of a pocket and you can't pull it out from the back.
https://da2lh5cs8ikqj.cloudfront.net/car...
The good news is with enough heat , a steady hand and good spudger pulling the front off really isn't that bad as far as glass removal goes. Way better then an iPad for sure.
Score 1
Comments:
Thanks for the answer. How much do I need to disassemble from the midframe? Once I get the front off, do I only need to disconnect and remove the LCD? or is there a bunch of other stuff I need to remove?
by
Yep, unplug and remove. Pretty strait forward. With it already being broken there isn't much to worry about. The other good news is that if you do manage to break the glass/digi it is a fairly inexpensive part.
by
Add a comment
Add your answer
Tab repair novice will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 71
