How will I turn on my phone?
How will I turn on my phone if it just gone black and it is getting hotter and hotter
Comments:
was the phone dropped or did it get wet?
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
If its getting hot its shorting out somewhere and you don't want to turn it on . If the phone got wet this can cause heat issues . The battery going bad can also cause heat issue. are you using a bad battery charger the battery could be getting overcharged. You can try removing the battery and cleaning the contacts
Score 1
Add a comment
Add your answer
Kareen Anne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 23
