Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
105 Questions View all
backlight problem ... inverter? panel? wire o logic board?
hello guys this is my first question here so be patient with me (and my bad english)
i have a backlight problem with an imac model no: A1224 and EMC: 2266,i have followed your guide to disassemle it and now i m confused on what is broken on my imac; those are the test that i have do:
- if i power on my imac and use a led torch to illuminate the display i can see everything and everything works great.
- if i disconnect the ccfl lamp cable from inverter to put 4 fully working ccfl (refurbished by a broken lcd monitor) and power on my imac the ccfl lamp dont power on
- if i measure with a multimeter on 4 pin connector on the inverter board i can see on the upper 2 pin 12v and nothing on the other 2 pins
- if i measure with a multimeter set in continuity mode the cable that connect: (first 2 pins) power supply to inverter board and (other 2 pins) logic board to inverter board everything "beeps" so the wire i suppose that is good.
my inverter board is a Apple part number 612-0051 someone can tell me what is the rigth pinout/voltage on this fully working board ??? i don't want to buy a new inverter if i'm not sure that it is the problem.
Any help, other test or suggestion are really appreciated regards
Add a comment
1 Answer
Chosen Solution
Replace the inverter, if you can see the desktop, that's it and they are cheap.. Here's how: iMac Intel 20" EMC 2266 Inverter Replacement
Score 1
for sure is more cheaper than logic board... but i don't waste my money expecially couse i'm italian and i can't find easily this spare parts, so i have 2 questions:
- can u tell me the exactly voltage that i have to find in the 4 pins of a new inverter like mine ?
- is this one (that is in belgium) compatible with my imac ?
thank you
Add a comment
Add your answer
Francesco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 288
