Guides and support for various television (TV) brands and styles.
9046 Questions View all
42PFL5405H Philips TV does not turn on. Red light blinking 3 times.
Hi, during normal use the TV (auto)switched off, and the standby red led started to blink 3 times at regular intervals. I suspect it may be due to broken power supply, as the day before we experienced some overlaods during a bad-weather night.
Do you guys have any advice on what I could check with limited equipments in order to avoid spending (in first instance) lots of money for a professional repair?
Score 2
2 Comments
P.S. I already have tried to unplug it from power source and leave it unplugged for an hour or so, but nothing changed
by
Hi, I have the phillips 26pf5521d/10 does not come on but the red standby light flashes twice then five times then seven times could this also be a power supp fault ? Mike mickeigg@hotmail.co.uk
by
Add a comment
Most Helpful Answer
This is most likely a main power supply failure. It will be easiest to replace it, but you may be able to repair it. Remove and examine for blown capacitors and cold solders.
Score 2
1 Comment:
Do you know which is the byw98-200 diode in the power supply board ?
by
Add a comment
Gianco, post some images of your power board with your question. For that use this guide. You will at least need some sort of multimeter. Level 1 Error 3 is a 12V error, most likely coming from the power board. This error can be caused by a shortened diode on the power board. Look for something like D210 and see if it looks "odd". Of course you can always go and replace the complete power board.
Score 2
11 Comments:
If had the same Problem on my Philips 42PFL5405.
The Problem was a Schottky-Diod (D210) on the Power Supply Unit. After replacing the D210 (Type SB3200, 200V, 3A) the TV works fine again.
This is a know issue with this TV.
by
[image|2116938]
In my case it was really D210. As i got TV (42PFL5405H/12) to repair, diode was already changed and so i don’t know it it was origin part. I replaced it with same type (1N5402) and it worked only for 30 minutes. Then i replaced it with RGP30 diode and since then TV is working again. Both broken diodes showed about 10 Ohm of resistance in both directions.
Please leave a comment here if this information was of any use for you.
by
@alexnoname great to hear that my 5 year old answer was actually right. Glad it worked for you and thanks for posting your 'answer'
by
Hi! I got a SQ552.1E LA TV that blinked 3 times. This diode was shorted out, changing it fixed the problem. Thanks everyone!
by
Hi! Another 37PFL5504 fixed that blinked 3 times!! My original diode was SB3200, 0 ohm in every direction. I've used RGP30D. Thanks everyone!
by
Show 6 more comments
Add a comment
replace the 24V rectifier elements in the secondary circuit - Schottky diode SB3200 and filter capacitor 470uF.
Score 1
2 Comments:
I replaced with a new power board, but the same issue. Are the 24V rectifier elements outside the main power board?
by
@meeker99 no there are not. Give us your exact make and model as well as more history as in what is going on and what you have checked
by
Add a comment
I've attached pictures of the location (see my finger) of SB3200 diode, 0 ohm in every direction.
I replaced by a new RGP30D.
Score 1
Add a comment
I love how you guys keep this post alive!
My TV has just stopped working, and it turned out that indeed the Schottky diode is faulty.
I am about to order it and replace tomorrow.
Thank you all! :)
Add a comment
Add your answer
Gianco will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 171
All Time: 32,016
