Model A1199 / 2, 4, or 8 GB capacity
94 Questions View all
What kind of mild adhesive is used on bottom bezel?
When replacing the battery on 2nd gen ipod the bottom bezel won't stay attached. What kind of mild adhesive is recommended?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I'm a fan of a tiny bit of clear silicone myself for small fixes like that. It holds strong, is easy to work with, and can usually be cleaned up/off of things if you ever take it apart again.
If you want to duplicate the original adhesive as closely as possible, I would lay some double sided tape over the back of the bezel, then trim it around the holes/edges.
Add a comment
Add your answer
Denis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,166
