Released in 2012, the Toshiba Satellite C850 is a 15.6-inch notebook with a choice of either AMD or Intel processors. It has USB 3.0 and can be configured with up to a 1TB HDD for storage and discrete graphics.
37 Questions View all
Is there a way to Bypass the system password
I'm locked out of my Toshiba Satellite c855d-s5307, my three year old daughter was playing with my puter and somehow changed my password and now I can't get in at all
Score 1
2 Comments
I think you can get software to reset or recover your password. Let me check a bit more.
by
Mike, will this be the password for your Computer (BIOS ) password, or the one to your Operating System (i.e. Windows? Which operating system are you using?
by
Add a comment
Most Helpful Answer
This link might be helpful in resetting your password. I never used it myself, but I read that it's not bad.
http://www.pogostick.net/~pnh/ntpasswd/
Score 1
1 Comment:
This will work. You will need another computer that can burn a CD to burn a disc that you can use to reset your password. I have used this tool a couple of times. The process is a little more involved than just inserting a burned CD into your computer.
by
Add a comment
I searched around a little and came up with a few links. You can try these, though I have no experience with them myself.
http://www.resetwindowspassword.com
http://windowsrecoverpassword.com/
Add a comment
You must burn a password reset CD similar to what was posted by Jesse.
Insert the Burned CD into your computer drive. Restart computer. Continuously tap the F12 key until you get to boot menu.
Pick the CD/DVD drive in the menu to boot from the CD. Let the CD disk startup and follow the directions to reset your password.
Add a comment
i had this same problem if you have nothing you want to save then do a reinstall of windows that way you can set up a new password.
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,349
